My son is making a fixture for the mill out of scrap steel. Very expensive to buy. It is for engine rebuilding . Can you guess what is going to be for? He is about half way done. I'll keep updating.
NoHas it got something to do with the cam bearing tunnel of an engine block?
No. The diameter of the pin you are looking at is 1 3/4" The reason I know that is I just got two 1 3/4 Fenner locks in the mail.Fixture to hold pistons in milling machine so they can be milled or valve pockets flycut, very impressive work! Those look like piston pins in the heim bearings, so that's my guess...
No. The pin is 1 3/4 Dia. that is sticking through the bearing. They are adjustable up and down and lock at that height with the handles. This is being made super heavy duty to use on any size motor including All size diesels.Fixture to hold pistons in milling machine so they can be milled or valve pockets flycut, very impressive work! Those look like piston pins in the heim bearings, so that's my guess...
No.Fixture to hold pistons in milling machine so they can be milled or valve pockets flycut, very impressive work! Those look like piston pins in the heim bearings, so that's my guess...
No.Passage drilling for either 4 bolt mains or nothing. That’s my answer and I’m sticking to it.
That pin that is through at an angle is just a test to see the angle travel for interference. He is setting it up to use on the 58 inch mill table it is on. But he will need a 8 x 18 inch riser for the head to increase table to spindle hieght.
He bought this rotating 24 " table to make a riser for the series II. he is ordering a piece of 18" diameter x 2" wall seamless cold roll pipe to make the spacer. The table is setting on the craftsman tool box. That table has to weigh every bit of 400 lbs
You guys depress me with the amount of skill you possess LOL
It was all I could do to keep from simply posting “SHOW OFF!”...Bwahahaha!I know, right? It just ain't fair. lol
