Lifters are the question
Holy Roller
Nederland Texas
I'm using a Comp hydraulic roller that's I think 549 lift. Any recommendations on lifters ..comp, Howard's, trick flow, ect. Your advice is highly appreciated. Thank you
Hyd. roller block to start with? Stock lifters are fine.
LA FT cam block?
The Magnum’s and the LA blocks just before them were engines that used a Hyd. roller cam from the factory. Are you using this series block?
What about them?
I don’t understand why you ask about them.
Yea you need to specify what you got to get the correct info.
Is that you mention it...... and didn’t say it....
Big block or small block???
Good info in
Good info out
General info in
General info out
Well, if I had noted I was in the big block tech section.... LMAO
BAD ON ME AS WELL!!!!
Call me dumb ***!
LMFAO!!!
:rofl:
^ I've seen good things about them, also Morel. Lunati are Morel, and are quite reasonably priced. S/F...Ken M
