rod7515
Working on my 66 Dart. The trim around the rear window will not sit down tight against the window, There is a gap all the way across the bottom of about 1/8" or more as you can see in the pic below. My question would be how ddo I get it to lay down tighter on the window rubber? Do I need to use some weatherstrip adhesive on it or maybe some Silicone? What are my choices?
Thanks Rod
