TrailBeast
AKA Mopars4us on Youtube
A local buddy came up with a used GV overdrive for his 71 Swinger and I offered to help him with it since he had never done much of anything gear train wise before.
We split the hump under the drivers seat and welded in a section to make a taller hump to clear the overdrive unit, re designed his exhaust pipes to go around it by taking a section out of both pipes behind his crossover and adding them in the front to move the crossover behind the OD unit.
We shortened a spare driveline to fit the new longer unit, and moved all his good U joints to the shortened driveline.
Got it all installed, filled with fluid, wired up and.....It didn't work.
We could hear the solenoid activating but overdrive wasn't there.
Come to find out it was a destroyed unit with metal slivers in the screen filter.
Well, for 800 bucks Gear Vendors apparently will take a bad unit and rebuild or replace it, so this is what he is going to do.
I tried to talk him into doing a 42RH OD swap because we could do it for around 400 bucks total and that includes the shift kit for it, but no go.
He has a mildly hopped up 318 so the 42RH would be the ticket in my opinion.
He wants that GV unit.
The GV unit came out of a stockish van and shouldn't have been trashed by too much power, so we figure it must have been abused in some other way.
Bummer.
Bummer.
