plumkrazee70
I installed the US Car Tool subframe connectors, some time ago, but mistakenly removed the factory brake line because it was being replaced.
Trouble is, the subframe connectors are welded in and the prebent factory brake line from inline tube (which is excellent btw) can't go into it's original location due to the subframe connectors being in the way. I should have know, but spaced it.
My plan is to cut the prebent line flare it on both ends and install this in between. I'll drill a small hole through the subframe connectors with a grommet for the braided line to go through.
Hopefully this post will prevent the next guy from having to do extra work. I'll post up pics of the final product.
-3 AN is 3/16 brake line, right?
