Timing chain
Before installing the distributor and oil pump drive
shaft, time engine as follows:
(1) Rotate crankshaft until No. 1 cylinder is at top
dead center on the firing stroke.
I think what many are missing is the cam timing and the dist. timing are two separate procedures. Dist. requires finding TDC compression stroke #1 cly. Cam / crank does not.
Follow the procedure in FSM and you won't have any issues
LET'S NOT!! SKIP IT!!! Thanks, by skip it I mean I understand the theory, didn't mean skip the step. No need to beat that. Got it.
LINE THEM UP AT 6 and 12 because then you CAN SEE IF THEY ARE OFF FOR CERTAIN.
Unfortunately the engine is together so that's gonna be tough.
I'm trying to figure out if I need to go back in and have a look....................
In your opinion, Del, from these crappy pictures, am I a tooth off?
Thanks!
Sorry LOL I had to go to work.
I agree, however, for someone who does not quite understand, it's good to go over it absolutely correctly.
I understand that is how you do it and have no problems. I on the other hand, don't set the distributor in until the engine and trans is bolted in the car. Plus I am moving the crank all the time adjusting valves and what not. The fool proof method is to find TDC on the compression stroke and drop the distributor in so it fires #1.
Straightened out the rest of the wiring issues, tried again, fired right up. Then died. And would not run in IGN run. So I tried the brand new ECU with the dirty dented box. Nothin. Nada. Zip. Shocker.
Back to the old ECU. Again, fires on IGN 2 won't run on IGN 1. Classic ballast fail, right? Swapped ballast, same result. Jumpered hot wire to coil. BAZINGA! Returning ECU and picking up replacement later.
So for not having tuned the carb at all, I'm happy. However, as soon as you crack the throttle at all, it stalls, stumbles or backfires. More to come.
All that is 100% correct, but notice nowhere do they acknowledge that the picture "fig 26" is timed up on #6. This is what makes people slip up and get the distributor 180* out.
It does not say where you are in fig 26, agreed. But what I always figured was the Chrysler engineers meant for the two paragraphs to be used together. Set it up dot to dot for six, that's in step 11, for the timing chain. Then roll it around to one and drop in the distributor, that's in step 1 of "Distributor Timing"
Seemed logical to me.
Straight edge, center of the crank to the center of the cam bolt. Mine is 180 out but you should get the idea.
Take the fuel pump concentric off for a more accurate look. Straight line point A(crank) to point B(cam)
It is and you and I get it.......but some folks need a clear picture. Not saying anyone is stupid, but for instance, certain things I need a picture of instead of an explanation. We all understand things and receive input differently.
I'm not it forum for a long time. While you're at it, it would be nice to add a tensioner. you wont regret.
Wwelllllll that is probably a good idea, but that ship has sailed. Engine is assembled and running.
I have lost 3 timing chains. 2 had tensioners, one had nylon teeth over cast gear. No tensioner for me.
Interesting. Elaborate please, if you would. By lost do you mean broke, jumped timing, flew out of the engine and couldn't find it? Do you think the tensioner had anything to do with it?
Who makes the best timing chain for a 318 la, Cloyes?
Best? I can't help you. I used a Comp Cam that I had laying around the shop. Anything that doesn't have nylon teeth is a step up. LOL. I would think any of the big names like Melling, Cloyes, Edelbrock etc. would be good.
One the chain sheared, link type not roller type, my theory... chunk of plastic (i found many pieces ) from the guide got between teeth and chain. Chain couldn't crush it so chain sheared.
Two, guide came apart and chain skipped a few teeth.
Three, nylon teeth on cast cam gear, 160000 miles nylon cracked away and chain skipped a few teeth ( anyone want to guess what engine that was? Hint not mopar)
I saw I think a 70's 351W with a plastic cam gear once. Did I win?
Small block Chevy every 70,000 in PU trucks. Chevrolet made me a lot of money. Still won't look at one for myself 40 years later...
Very close! but no, the last of the 289s had them and I got one :(.
I think they were also in the 302's and the 351's as well, till Ford finally gave up on the idea. The funny thing about that one was I had a how to rebuild Ford engines book and it warned that at about 150,000 miles the gear would go. Wish I had read that BEFORE the gear went!
The last sets I've used we're from S.A. and Howard's. About $50.00 for a double roller. Some guys have said Cloyes quaility has dropped a bit on their castings. Don't have first hand knowledge.
I have an S.A. in stock on my shelf. I also have a 25 lap used Cloyes on the shelf.
That is true for most every style V8. The reason the cam timing is done dot to dot is because it's much easier to get them aligned when they are closer together such as the 6 o'clock/12 o'clock orientation. Imagine how many times you would have to install/reinstall the timing sets to get it perfectly aligned if you used the 12 o'clock/12 o'clock orientation. Most people don't realize that the dots on the timing set end up at 12 o'clock/12 o'clock to correctly install the distributor because the timing cover is already installed. Yes it can be confusing, but as has been mentioned and confirmed by several others, it really is two separate and different procedures, but are often confused as being one in the same.
On my last build I ended up using a Summit double roller, it came in with a 1/2 degree of what the cam card said.
I had a Comp chain that was not worth the metal it was made out of, it must have had all seconds thrown in that box.
20 year old Mopar Performance I had new in the package was perfect.
Lastly I always liked cloyes, the last one I had rocked 4 degrees on the cam key-way, maybe I just got a bad one, but you have to check them all.
