I have my thougts on that. Prob does not realize the sun machine is in distrib degrees not crank.
Was just a matter of time.
If I told you I would have to block you!Who’s Guy Joe?
I thought degrees was for tempamature. Are you trying to confuse me?I have my thougts on that. Prob does not realize the sun machine is in distrib degrees not crank.
The gov did that already Farenheight/CelsiusI thought degrees was for tempamature. Are you trying to confuse me?
Don't get the ribbed ones, they can be rough!
Or, to reuse it, turn it inside out and shake the fuxxk out of it!Ribbed condoms, for her pleasure...
Put them on inside out, for YOUR pleasure....
I’m hearing that one should always use RUBBERS...
not if you want to feel the road...
No curves?I know I have to what the info I get. I use around ten different sources of specs in all. Some in distrib, some in crank. Its really the earlier ones you have to watch almost no curve in some of them (40-50's)
They are for the cold ones! Just like winter tires!
20° initial with 36° total is pretty strong. LOL And no ping?
I was going to pipe in on, it but just grabbed a bag of chips instead!
EwwwwwwwwBe careful when you shake it, some of it may get in your eye...
Is it a busy ditch or a dizzy *****?And we've veered off the road and are running in the ditch. Much more fun in the ditch me thinks!
Don't think we are getting the severe part, but chance of showers this afternoon. Need to finish tilling and get my garden planted. Nothin big, Have a few plants to put in. Need to go get some seeds.Severe storms today for us supposedly. Probably should go work on finishing the garden prior.
