Putting big block in 67 Valiant, what engine brackets?
4fortyDemon
St George, Utah
Spoke to a few people and apparently the brackets that mount to the block that the mounts bolt to are different between bodys... B vs C. What brackets do I need to do a big block swap? Thanks, Mike!
Slant 6
I have the Schumacher/6 to bigblock mount kit but need the brackets to the block. I was told that the brackets are different
I thought the Schmacher kit had everything you needed? A factory big block drivers side mount is unique to Darts/Barracudas and 65-68 C-Body's. The passenger side is the same as any big block Mopar.
HemiSSDart, I have the mount kit packed away. I thought it only has the biscuits. Thanks for the info though...
