Pumpkinduster
Hey guys I just set my motor and tranny (318 - A904) in my car last night 74 Duster. We have installed the QA1 K-member to swap from a slant 6 to 318.
Yesterday I ran down to my local Mopar wrecking yard and picked up a set up brackets for a 67-72 SB. Once I set the motor in things aren't lining up. I have the mounts on and lined up to the k member, but it seems to be way to close on the drivers side. It was late so I hadn't messed with it much last night.
My question is can someone post a pic of the mounts and which side is which so I can compare them when I get home. I will lift the motor and snap a pick as well. I should have done it before I installed them. I want to make sure that I got the right mounts and that I have them on correctly.
I attached a pic from another post and I think mine look like these.
