Been there, done that... I’ve got a destroyed short block to show for it!
Glad you cleared it up!!
Let me guess....... crank key straight up..... top gear dot straight down.
Yep.
Explanation here - Finally found my problem...warning to all.
Here is the picture I never uploaded. Sorry it is fuzzy, might have been why I didn't follow through. Note the dot to the right next to the teeth.
wuh-wait?
You're supposed to time to that wee dot, that's barely visible? Or you timed to that and you were supposed to time to the big monster dot?
A lesson in why you should always degree the cam.
Installed like whats in the pic, the cam is advanced about 35*(2.5 teeth).
It’s not an uncommon occurance.
Um....uh oh. Me thinks I might have the same problem.
I bought my motor as an assembled short block and heads. Heads were fresh and the short block checked out Ok. Took the t-chain off (but can't remember why lol) but I put it back on similarly to what's described here. Didn't degree the cam because it was stock and I don't have the timing specs. All I know is the motor came out of a 1990 Durango or truck (roller cammed 360 LA). If I did put the chain on wrong I hope the cam is so mild that the valves haven't hit the pistons as I just got it running! Did a compression test before. I'll have to do one again and compare the results.Sure hope not...
Man this is an awesome learning tool! This should be a sticky thread!! Thanks for sharing!!Yes, I was supposed to use the small dot. It wasn't all that invisible, I just overlooked it because the zero was so large. Wish I would claim that I was at least drinking, but I know I wasn't.
Just for reference, here is how it looked when I put it back together:
I never would have known, and probably have the cam in wrong in my car now.Yes, I was supposed to use the small dot. It wasn't all that invisible, I just overlooked it because the zero was so large. Wish I would claim that I was at least drinking, but I know I wasn't.
