HELP!!!!
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
My car's not running right. It's green.
That's because it's not really all that green...
The Green Hornet!
More green car ****...
You need a power plant swap! Change out the dead on there heels gerbils for new hamsters. They still get good economy well consuming only a very little bit more in fuel.
Of course there’s always a larger cage option for ground hogs.
We're gonna need more info... Summer or winter air in the tires? What brand is your underwear? Does spark jump from your fingertips to the door handle?
Are you sure it's not running "left" as opposed to not running "right"?????? There is a difference you know??? More info needed....how old is your cat/dog............do you get dizzy when you get out of bed............are both your feet the same size............how long can you hold your breath.....were you born during the day or at night??? These questions/answers are important!!!
Must be algae in the gas.
And not the gas in the car ether!!!
Clearly, this is a car problem. Banning the car should solve the problem.
