Two part question np 445 bolt up and motormounts alignment.
bell housing is a 2899163 dodge (for 11 inch clutch) got it bolted to a 318 la block. I pulled the np435 and stabbed the np445 and bolted right up so the input shafts are the same my guess. 325 poly (motor is out) not been drilled for a 4 speed. But according to wilcap hotheads CPL others not too big of a problem. I can't find info on early poly to np 435/445 4 speed threads for this. Mainly see a833 to early hemi poly.
Seems the 325 poly will drop into the LA 318 motormounts, the measurement is very close and close enuf to use shims. Now are the v of the 318 block same angle as 325 block or how would I measured that angle fitment.
Thanks
Thanks
