[FOR SALE] 1976 Dodge Dart Lite
moparblood
n.y.
Factory Slant-6
4-Speed Overdrive
7 1/4 rear: 2.94 gears
1-Year Only Gas-Saver Package
Car is not drive-able. It is being sold as-is as a complete car. Will not part out.
Has a running motor
Aluminum intake
2.5 inch exhaust
Aluminum transmission
Brand-new clutch
Big-bolt pattern brake assembly
Clutch pedal assembly
4-speed tunnel
Front bench seat
Rear seats
All glass is good except front windshield
Rally wheels
Rear bumper with aluminum assembly
Steering wheel and column
Wiring, etc.
$3,000
Hi there. I am interested in the 76 Dart lite. Other than the damage seen in the pictures, is the car drivable? Are there any car parts (rt fender, hood, bumper, grille, or anything else) included in the sale? Most importantly, is there any frame damage? Does the right side door open and close well? Thanks in advance.
Rob
You need a bushing for any manual transmission. That's for another thread.
the car has frame damage as the wheel was pushed back a few inches. the ps floor board is kinked. its a Great parts car, and will have to be trailered. As far as the bushing in crank, you can probably get away with a roller bearing. car is in 12571 zip!
i would buy the car if you can help with the shipping to az 85032
i would like some money help with the shipping, it may costs $1000 to phoenix..thanks
That 4-speed shifter looks too close to the bench seat. Is this from the factory with a bench. Is the car all original?
Looks like the seat is pretty far forward. Perfect if it's in second or o/d.
the car is all original. i took the stock shifter handle out and put a pistol grip in it!
so i put the stock 1 back and its in 2nd gear.
