N96 One-of-None 1972 Demon Fresh-Air Hood
Way cool and some good ideas. I'm doing the same with my 72 Dart. Still in the works.
Mark,
That's good. So the twin scoop fits with some overlap? Looks like you followed the basic outline but with a 2 inch lip from the bracing. What did you cut with a wiz wheel or air snipper? Are you going to seal it? I may use a pan but not seal it.
Thanks,
Marion
Can someone restore the photos on this thread and sticky it/them, please? This is too good to have to download a bunch of pics just to follow
I just used a cutoff wheel and followed the structure, actually my friend did it for me. I'm thinking about trying an air cleaner setup from a 71-2 B-body with N-96 hood and seeing how well that will seal to the hood. I'm concerned about the rain water getting into my air filter and that setup has drainage.
Cool, how does it fit the triangular hood bracing/structure?
I'm going to use an offset base unit on mine to Center the air cleaner more in the Triangular area but I'm concerned about and wondering how big is that damn GM seal how much lift can I get off of that
I used the same rivets and washers that I used to attach the base to the cake pan. See pictures with directions below.
The arrow points to the channel in the gasket I used to place the washer and rivet.
This is looking at the outside of the gasket as it is attached to the outside of the cake pan, you can see the rivet and gasket. I pushed the gasket up against the lip in the pan and measured the distance that I need to drill the holes in the pan so the gasket would fit tight against the lip. Place the rivets every 4 to 6 inches.
This is a picture looking at the inside of the pan. You can see the lip on the pan and the end of the rivet just to the left of my thumb.
Another picture looking from the outside of the pan and how the gasket hides the rivet. I painted mine black after I had everything installed to hide the white rivet and washer.
Here's the rivets and washers I used.
That is cool as can be! How much distance for Crush do you have on that steel from where you mounted to the cake pan as far as the raised area of the seal
Look at post #23. The pictures attached to that post were taken with the hood closed and they show how the seal is seated against the underside of the hood. Also, I used cheap modeling clay stacked on top of the air cleaner lid to measure clearances. However, I did not cut out the "triangle", used the original hood opening seal in the original location (see post #18).
Excellent Job, Sir! I ordered the seal, just didn't know how tall it was
Think I made mine around 2016. Seen this thread was brought back so I figured I’d finally share my setup. Put a little spin on the decal since it’s in my duster. Wanted to keep it Plymouth, so I went with air grabber. Matches up with my dual snorkel scoop perfectly.
I'd really like to add a fresh air intake system to my Ply. Signet.
I build one for my 74 Duster. 18" x3" cake pan, the above gasket. Kinda a pain to find , and a Speedway Motors top ( after summit held me up on a K@n for over 3 months. Then canceled my order. In all fairness, getting a 14" K@N top ain't happening. I have not ran it yet, but I'm Really needing to!
A Speedway Motors top? What is that? I'm not familiar with them Their top may be the only one that would work? Would a repro N96 set-up be too costly?
Okay, so we all know that Dodge did not make a N96 fresh-air hood and air cleaner to match the dual snorkel hood scoop that came as a factory option on the 72 Demon/73 Dart Sport. That is why I decided to make my own I call it the home baked Demon Ramcharger fresh-air system. Proving that you can have your cake and your fresh air too, of course the cake would be Devils Food! The air cleaner seals to the hood and encloses both hood scoop air inlets (in stock location) providing fresh air to the carb. For reference, Im running an LD-340 intake and 1/2 spacer under the carb. The list of parts I used follows the pictures.
Parts List:
17x3 inch cake pan; EBay: $39.00
Air Cleaner Lid from N96 Ramcharger/Air Grabber air cleaner assembly; Herbs Parts: $105.00
Ford Motor Sports Air Cleaner (I used the base plate and air filter for the correct drop for my set up and the correct diameter for the N96 lid); Summit Racing (PN# PRO-302-350): $48.00
Goodmark Industries GM Cowl Induction hood seal, installed inside out (PN# GMK-402023006912): $22.00
Mopar decals from Performance Car Graphics (to counteract Ford and Chevy parts): $41.00
Misc. Parts; Rivets and Paint: $15.00
Total cost with shipping: $270.00
Certainly, you could do this for less money if you dont use the N96 air cleaner lid and decals.
Thanks! You gave me great info...much appreciated and nice job too BTW. Know anything about best place to find new rear leaf springs for my 73 dodge dart sport 340, thats now a stroker 408, that will raise stock height by 1 inch??
