yellow rose
Overnight Sensation
I think I'm there. Running pretty sweet. Much stronger response than the Edelbrock when I stomp it, and clearly tends to run leaner when the power is not needed. Have to wait for spring to put it on the track.
Went back to 2-1/2 turns up for the rods, and changed the spring to a hardware store spring that I lucked into, maybe? a bit stronger than stock but longer by 1/4". The air door I set at 1-3/4 turns from just coming up level. No choke so the motor has to be fully warmed for no hesitation when I snap the pedal down, but once warm no issues at all.
Have all my numbers pretty close to where I want them. Idle mix at 14.8 or so, then 15.8 to 16 when just cruising along, but drops to about 11.8-12 WOT. Still goes way lean with steady light throttle applied (17.5/18:1) but really no problem really, as it's only a short term situation. Now it's time for a new set of NGK's to check after driving for a while.
Thanks for all the help getting through this!!! Now I have to come up with something new to obsess over!!!!
So the plugs match your O2 readings? I never go by a number unless it matches the plugs first.
