jason's duster
OK so I’m going to make a long story short my engine was making a very slight knock so I pulled it it’s a 340 out of my 69 Dart and I found these in oil pan. Any ideas where they came from?
That's not a valve seat, that's a valve LOCK.
And yes, that would make sense if the piston made contact with a valve and shattered the lock. So you likely have a bent valve and a valve spring that is free of its retainer. Not good.
EDIT-
Based on that picture you'd better make it two bent valves.
Any reason to remove rotating assembly or just repair heads?
It could be depending in the diameter of the debris... Hard to tell in the picture he posted...
I agree pictures can be misleading, but with that kind of curvature the diameter is way too small for a seat.
If it's got a "small knock" like the OP described the whole thing has to be disassembled.
Ok I’m tearing down to the smallest components. Thank you for all your help. I will update in near future. And yes liquor was prob a factor. Can’t fix stupid.
