69 Cuda A56
1969cuda340
indy
Pictures of my A56 Cuda
Had the car since 1985. I painted it when I was 19. Now I’m having a professional do it right
Tons. Can share on the side with a PM. Your post does not need my car in it.
Using your photo... My question is I have some rot in the area with the green circle. Can I cut that out and replace with a piece of new metal??? THx
It depends on how bad the rust is under the inner fender. There are 3 layers of steel. Inner fender, upper control arm bracket and then the shock tower. I had to cut out and replace a piece of the UCA bracket after I got the inner fender off. jim
