TrailBeast
AKA Mopars4us on Youtube
I recently did this conversion on an original unmodified 1973 8.25 rear end housing.
All went really nice until I had a nasty little intermittent scraping sound that would come and go.
At first I thought the backing plate was too close to the rotor, so I got in there with a flat blade screwdriver and opened up the gap a bit (1/4 inch or so)
Still had the exact same intermittent metal to metal scraping sound, and even noticed a bit of metal dust on the wheel.
Found it.
In this picture a red arrow points to a ridge on the inside of the disc surrounding the emergency brake drum built into the disc.
This ridge was hitting the raised rib pointed out on the backing plate.
I took a 4 inch grinder to the ridge on the drum taking it down flat and that solved it.
Taking that ridge off has no affect on the E brake surface or shoes.
Just in case someone does this swap this might save them from the same head scratching.
Other than that the entire swap bolted up flawlessly with zero mods other than longer wheel studs to make up for the disc thickness.
Found it.
