magnum 360 pushrod lash
Eric Mulay
san luis obispo california
i just changed a cam and lifters, when i put the rocker arms back on, its 1 on the rocker arm, do i just tighten that all the way down?
i cant find any instructions except for GM lash,. but GM has a rocker stud and these do not, so its not the same
Hydraulic lifters?
Jake
so, there is no lash adjustment like on chevy heads?
A bit late to the party, but no lash settings on a Magnum Mopar but rocker geometry is a thing if you changed heads or head gasket thickness.
In case you were wondering if I have any direct experience with it.:D
DO they have the 5/16" bolts that hold the rockers down? If so, they torque to 15-17 LB FT. They are non-adjustable. However, pictures of what YOU have would assure that we are giving you correct advice.
