Looking for the new or used.
For my '67 Barracuda but all these were used on many years and models.
Updated
Headlight Switch connector, 2258102 FOUND
Fuse box terminals FOUND
Fuse holder with male spade terminal rivetted on.
Fuse holder with crimp terminal.
The ones in the A/C or rear defrost slot would be best but I prob could make others work.
or a used fusebox and I'll strip out the terminals as needed.
Connector to fuel sender cable complete (including terminal at other end).
In better shape than this one
Preferably with the wire all the back and including the grommet, and the terminal in the trunk connector.
These may be the part numbers
connector 2230985 FOUND. I'll splice this one in, but would prefer complete cable.
connector, cable with grommet 2257444
Seems to be the same cable used in A, B, and maybe C bodies for a number of years.
Updated
