I printed those pages the other day and spotted the two 282 HDP listings with the same part number for the Big block pgs 98&99
only see the 280 HDP on pg 95 small block
a 280 h you would think would be single pattern DP dual pattern but Crower is not consistent
Lets hope it's not just a white box cam like the 278H Torque Beast and 288H Power Beast which are both dual pattern cams without the DP
Crower makes my head hurt
but I've used their custom grinds quite successfully , and use the 281HDP as about the biggest I'd go with stock manifolds (112 LCA to hold down the overlap)
best I ever did with stealth stock manifold build was less seat timing than stock, 218 @.050 .525 lift had to idle stock
Monarch have not heard of that one for years
best to talk with Shane
any idea if Crower uses .005 or .006?
PRH compare that Monarch with even a 268 comp and you might know how much I like that comp, we've come a long way
