I've done several sets of Legendary buckets - high back 72, 73; low back 66 and 69. Take photos first, keep the old covers as reference. Inspect your foam and springs carefully. The springs often need a crimp or two tightened at the frame, just look for rattles. Watch the centering as you attach the listing wires. Have the covers warm, like 72* or better. The rear stretch panel sometimes wants to tear at the side stitches. I do them on a low table w a moving blanket. you can compress the springs at the front and relax the tension in the back. Double check the centering before you do the bottom hog rings to the frame.
