Show your 5x4 small bolt pattern wheels!
Centerline Convo Pros 15 x3 up front 15 x8 in rear 5x4 bolt pattern
Here is another set of SBP wheels that came on the Dart. I'm not too fussed on the turbine wheels, so this is getting swapped out to LBP when the 8-3/4 goes in.
Just put these on replacing the original 13" wheels. Wow what a difference!!! Totally changed the whole look of the car. They are 14×7s with 215/70/r14 tires. There was a little rubbing up front on passenger side. I just trimmed the inside corner back an inch or so. No more the rubbing . money well spent
Here is an Indy 14x7 mag with NOS GY Rally GTs, and the Keystones 14x6 waiting for some radial rubber. From the pictures it looks like we all need SBP caps for our slots.
That's an interesting looking 69. Was someone a lover of Firebirds?
Original owner had some custom work done in the late '70's with some GM parts including an L88 hood scoop. I will put it back to B3 w/B5 interior, but will enjoy the patina for the time being. It's a loaded 340, 4 spd w/AC, 3:55 regular Barracuda.
