BeatersRus
Active Member
is there such a thing?
can it even be accomplished?
im trying to get this done under 2 grand budget for the turbo setup,all done and in.
max money i can stretch the turbo part is 2200...
this is assuming a mix of new and used parts obviously.
ive been researching a bit and can get a basic kit for 5-600 bucks but
then theres the exhaust,the limited engine bay and the fuel upgrades.
plus the control system.
even the ones over a grand dont seem to be complete.
are any of you doing Budget turbo builds and if so,whats your thoughts?
im working on a 318 magnum motor,single turbo,automatic.
thanks in advance for any help and,yes,i have read the bible,along with a ton of posts.
enough to know that i know nothing.
the goal is to be able to enter a car that is under the 3k budget next year if possible.
car weight is 3300lbs,running a stock 318/904,and 373 limited slip.
im still considering the right gear,esp after reading some of yalls posts.
im not looking for a killer machine,just a - we proved it can be done at the end of the day.
