Outboard motor question
pikewi
Comfortably numb
WI
Howdy
Not a mopar but....I have to put a new head gasket on a 25 year old merc 2 cycle,25 hp.
Should I use gasket sealer and what torque for the bolts?
Thanks for the help
Pike
Howdy
Thanks for the help
Pike
It depends on what type of gasket you use. If it's a composition style, no sealer. If it's the steel shim type, spray it with Copper Kote. Opinions vary for sealant on bolts, but I always do it on every head bolt I touch, whether they go into water, or they are blind holes. Keeps them from seizing up if you ever have to remove them and affects torque very, very little. I always use red high tempo RTV. Sorry, I cannot help with the bolt torque. What's the thread size and do they screw into iron or aluminum?
Howdy
Thanks for the help
Pike
That should be a no on the sealer. As for the Torque specs, you need to google it.... I am sure the info is out there.....
JW
Post the model and brand of outboard. I have some service literature on OMC/ Johnson/ Evinrude
Thanks Rob.
Composition gasket. I haven't removed the bolts yet
Go to Marineengine.com and dig around thru there. I downloaded factory parts manual. Handy as heck. I'll chk once I'm home from work.
Thinking they are 5/16 bolts. Guessing at 15 foot lbs. or 180 inch lbs.
