07 gmc full size van needs power steering gear replaced. Did i mention its awd diesel? This is going to suck and blow at the same time. Closed sign on door should be enough to ward off the time wasters.
I wouldn't think a 9 year old would know how vehicles and machinery work. I didn't know until after high school
Morning MOPAR followers. Time to load up and catch the red eye to the MOPAR worship grounds...Carlisle!!
Take that bullet out of your shirt pocket Barney!Morning. Back to base. Probably be out of contact a while. You all have fun
50? Uh-oh. Think i dont change oil on husqvarna that often. I think 100. 10w30 or straight 30 is my preference for air cooled.Did some maintenance on my mower yesterday, was surprised when date on oil filter read June 2018. At least the hours aren't that bad, have 75 on this oil, JD recommends 50 or annually. So will get filter and oil today, can't believe the wide range of viscosities they say you can use, guess that V-twin doesn't care.....
Briggs filter $13, parts master filter(wix) $3.50
sending you a PMTake that bullet out of your shirt pocket Barney!
Be safe with the idiots out there.
Morning everyone, heat is rolling in around here. Getting out early to check my wells, to hot when it's 99deg.
51348? Thats the common one.I'm changing it due to two years since last. Stealership did the 50 hour and I let them as they sharpened the blade and I was living in our RV at the time. I'll go with 10-30 thanks and I got the number for the Wix filter.
I went with Wix on my John Deere (Kawasaki) I can't remember the number but O Reilly's had it on the shelf. (I think it was a Toyota number) It was a little longer than the one it calls for and is way easier to get out. If I remember it has flutes on the end of the cup where the JD filter doesn't and it's almost impossible to get a strap filter wrench in there. No problem now.51348? Thats the common one.
Some yamaha watercraft use that filter too. That one is $32 from the dealer. The wix is built way better than the yammy one. Cut one apart.
Our JD dealer here carries and recommends the K&N filters. They actually cost about a dollar less but have a nut welded on the bottom, which makes getting them off and on very easy in tight spaces. The catch is, they don't have them for ALL models. Especially the large row crops that have filters the size of 5 gallon bucketsI went with Wix on my John Deere (Kawasaki) I can't remember the number but O Reilly's had it on the shelf. (I think it was a Toyota number) It was a little longer than the one it calls for and is way easier to get out. If I remember it has flutes on the end of the cup where the JD filter doesn't and it's almost impossible to get a strap filter wrench in there. No problem now.
Until a heavy-handed gorilla uses the same wrench to install said filter. I have had to remove some nasty stuck filers on many occasions.Our JD dealer here carries and recommends the K&N filters. They actually cost about a dollar less but have a nut welded on the bottom, which makes getting them off and on very easy in tight spaces. The catch is, they don't have them for ALL models. Especially the large row crops that have filters the size of 5 gallon buckets
Yep. Cut off the can and air chisel the filter base off. LolUntil a heavy-handed gorilla uses the same wrench to install said filter. I have had to remove some nasty stuck filers on many occasions.
