carcus
Member
I have a 1972 Duster 340 retired former Colorado bracket racer. Wiring harness was removed and when I got it had a new Painless harness installed with new Pro Comp gauges. It has a built 340 not sure what gears, 4 speed manual. Battery was relocated to trunk and had a track battery shut off switch from former bracket racing. When I got the car rewired still had the battery shut off switch that I took the pull switch off so people on the street could not disconnect the battery. It was in the on positon, still is. Car ran fine after wiring. One day starting it, turned over fine, new battery, but all power went off. Went to trunk and the one who did the install put the breaker box in. It tripped, I reset it, then turned it over again...then went dead. Removed battery had tested. Battery is perfect. Now, still no crank, lights, power. Enclosed are a few pics of the car and trunk situation.
