How do you like your Fast EFI? I have Fitech on one ride, have a Fast unit to put on my Dart whenever I get it done.
So far so good , easier than I expected overall , still need to lean it down more . Have had no trouble w/ wiring interferance , or anything like that , but the overall wire sizing was way off for a 68 barracuda , dont know what it was designed to fit close on . I went w/ the fast dist. to control timing , which is based on a chevy dist./very short , took a hell of a bunch of grinding/fitting on the pass. side front of my raised port heads .
I would recommend the locked out MSD mopar dist . for sure on the big blocks .
I do have an a once in a while backfire thru the throttle body ,after letting off the gas and turning a corner ,when I first touch the gas pedal after completing the turn , havent been able to figure that out , as it only happens about once every other time I drive the car , "which aint much."
I jacked the initial timing up to 24* , it seemed to like it .
OPEN FOR SUGGESTIONS ON THE OCCASIONAL BACK FIRE , probly something my dumbass aint got set right -------------------Bob
