cudamark
I'm still trying to figure out the correct 1966 factory kickdown linkage setup for a 4bbl auto. Anyone have a stock 4bbl. automatic 1966 A-body they can shoot a photo? I'd like to mainly see the upper bell crank assembly that bolts to the back of the head. In particular, the offset angle of the upper lever. I have plenty of '65 examples, but, they seem to be different for some reason. I have one '66 example, but, I need to verify it is correct. From what I've been able to determine, the lower linkage rods are also different between '65 and '66. The lever on the trans looks to be the same, along with the lower bell crank on the bell housing, but, the rods are bent different. I can only presume they were changed when they went from a cable trans to a linkage trans. Can anyone verify this?
Thanks, Mark
Thanks, Mark
