Lokar kits-Throttle cable also?
Richie
Kelowna BC Canada
Hi everybody:
I was wondering if Lokar's kickdown kits for 727s come with throttle cables. Thanks
I would suggest it if you using an aftermarket intake. RPM, Stealth, Air Gap, and possible other have a raised carb pad.
Air Gap..I'll use the stock one then. Just took the throttle cable holder off of the old 318 and will clean it up and paint it.
Just FYI:
I am running the stock Throttle cable with a Lokar KD cable on my Air Gapped 408/727.
I bought some nice brackets from AR Engineering - they work perfectly in this application.
My stock cable barely worked with a Stealth. God only knows if it was the original.
Just FYI:
That looks fine. My throttle cable is bran new so let's hope it works but with this new stuff now a days nothing seems to fit right :lol:
Just FYI:
Older post, but would you please provide more info on the brackets from AR Engineering that you used? Thanks much!
They have a website and Mancini sells them (and I had never heard of them before. Just a few keystrokes in Google)
All in the car now and everything works good..The old bracket looks a little barn yard but it works and the gross old wiring has been taken care of too :lol:Thanks everybody
