Pistonspeed
Member
Howdy all,
I have a '67 Dart GT that I'm doing a quick refresh on. The car was originally white, but in the early 90s was repainted a base/clear light blue, and now it needs new paint.
The car came with a blue interior which it still has and I will keep.
So I have a few options for paint:
1) White, single-stage as it originally was - I could also do a white bc/cc, but haven't decided yet.
I could probably use SPI white epoxy primer for the engine bay and the trunk, which would save me time. The primer is resistant to whatever chemicals it would encounter in the engine bay, like brake fluid for example.
2) Light blue, like it is now - I'm not sure what exact light blue it is; I don't think it's the light blue Dodge offered in '67. I would have to ask one of the previous owners.
But I could just go with the '67 Dodge light blue metallic. This would take extra work since I'd have to paint the engine bay and trunk... the color is obviously not available in primer. I could blue tint trunk splatter paint though.
3) SPI UV-resistant black epoxy - I've been thinking about this option. The car would be a satin black... not quite a flat black but obviously not a glossy black either.
Like the white, I can black epoxy the engine bay and the trunk area. In fact, I already have black epoxy so I could do the trunk this weekend. Barry at SPI said his black epoxy has the UV resistance of a mid-grade, single-stage paint. I could do this for now, then later decide on a different color. I also probably wouldn't need to block sand as much.
4) Any other options that go with a blue interior?
What do you think? What's your input?
Thanks.
Thanks.
