Matthew Quinn
Member
This build is a 340 stroker. 4" crank and 4.07 bore.
Not sure if this angle is something I should be concerned with or what avenues I could use to mitigate. The geometry seems to be way off. I understand I have the wrong style length checking tool as a I need a ball end and a cup end, however the diameter is correct, so the geometry should match although I can't get a length until the new tool arrives.
Just wondering if what I am seeing is abnormal.
