Show your 5x4 small bolt pattern wheels!
15x6 and 15x8 Cragars, before it had 15x7 and 15x8 Rallyes
Wheel Vintiques 63 Series 15x6 Front and 15x7 Rear, 4" backspace. 205/60 R15 Front, 215/60 R15 Rear. Ended up with about 1/2" clearance at wheel well and 1" at stock springs.
Anyone know where/what chrome lugnuts for these? I need mix of RH and LH...
Nope the leaf springs and perches are in the stock location. I do have to add a little air to the shocks if I'm hauling any passengers.
Mini tub? Those 8” rear look pretty damn good! What is the back space on them? Stock rear width? 4” pattern?
Ok, changed it since my last pic. Added some Cenferline 15x4s small 5x4 pattern out front.
Are your 8" rear rims the standard (no offset) 4.00" backspace? Thanks for the help.
I don't know which Ron has, but original centerline autodrag 15x8 1/2s came with either 3 5/16 or 4 7/8 backspace.
From the look of the second picture with the car driving away, i would guess they are the 3 5/16.
I will pull a wheel and measure I've only had he car a month so I'm not sure. They fit and fill the wheel well without rubbing but it's close.
I didn't pull a wheel but putting a tape measure against the back of the hub and eyeballing it Looks like 4" to me.
I have the small bolt US Mags on the front only.They clear the Kelsey discs.15",5" wide,2.50" backspace...bought through Summit..............Rob
Thanks ..it is nice that some companies still make the 4.00 in bolt circle.FYI I did have to round file the plastic cap where the lugs go to fit correctly.Also have to remove center cap before you can get socket on to remove lugs..
A vintage set of 4" bolt Cragars SS with a equally vintage set of Firestone Sports 500 tires.
Let me tell you that is was scary driving on those 48 year old tires.
I put the wheels and tires on the car to take a few photos and a short drive, but it felt like driving with roller skates up front.
The tires which still look like new and have very few miles on them are F-70 14's in the front and H-70 14's in the rear.
Here is a set of Cragars that were on a 68 GTS that I bought back in the late 80's.
Centers were not plated.
