Need help decoding broadcast sheet
Dads74duster
Member
Canada
We just pulled it from the car on Friday, I don’t have the white book and can’t find one for sale online, any help decoding would be greatly appreciated. 1974 Duster 360 4 speed, thx in advance
My eyes can't read that small print. Type the codes you are curious about. Letter and number please.
I’m interested in the rear axle, pinion and gear ratio. In 73 they still manufactured a few 489 carriers fitted with the older model pinion 1-3/4” instead of the 1-7/8” that usually comes with the 489 carrier. Any part numbers you can give me would be greatly appreciated
Vac fit: 54
Engine: 556
Carb: 33
trans: 803
Pin: 37
P/shaft: 760
Axle: 281
On line one going across, box 5 should have a single letter for the engine- I see L in your pic. That's 360 v8 4bbl. Line two for trans. box 2 = 21- That is 4 speed 833-Manual. Rear end should be line two going across box 4. What's in there?
The D codes I have are...
D56- 3.55:1 rear axle
D82- 8.25:1 or 8.36:1 Axle Housing
D91- sure grip diff
Leads me to these numbers on line 4
Pin: 37
P/shaft: 760
Axle: 281
In 1974 a Duster would have an 8 1/4 axle. Any numbers on a factory build sheet will be the end numbers for a 8 1/4. The E bodies and some B bodies had the 8 3/4 in 73-74.
