roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,800
- Reaction score
- 3,578
600hp at the wheels maybe.
I built a 446 years ago with bowl ported Ede heads, 13:1, MP 620 cam, M1 with a 1050/4500 on it.
Made about 625hp on the dyno.
Went in a 3150lb race weight 71 Cuda back half car...... went 9.80’s.
Works out pretty close:
That dyno has to be modest
The pic in your Avatar looks like LVD........is that where you normally go?
Is that where you ran the “10” a couple weekends ago?
My experience has been that most peoples cars/combo leave quite a bit of ET on the table.
Especially any type of “street/strip” combo.
Yes, I race at LVD. Are you from the area?
Okay, so forgetting about the actual dyno number.......
How much difference in power would you expect to see between your motor, as it is now, and a 10.7:1 stock stroke 383 with unported 906’s, .560 lift solid cam, an RPM intake and Hooker Competition headers...... with both motors being tested back to back at the same dyno, on the same day?
What was the date you went in the 10’s there?
I think one of my friends was running there that weekend.
I'd guess 150 -200 hp difference.
So my car should have 6 to 13% left in it then?
That's 10.32 - 9.50
Rocco, I say there is room for improvement but how much you gain is one thing, how much you gain against the calculator is another. Ether way, if your going to try and attempt to do so, first, just simply stated, good luck and have fun while doing so, but more importantly, do t loose sleep over what the calcs say it should. Just get what you can get. Keep hammering away at it.So my car should have 6 to 13% left in it then?
That's 10.32 - 9.50
10.32 might be believable. I can definitely see at least a 10.70 with the converter change.
My trap speed and RPM is 124mph/5300. That's with a final gear ratio of 3.55:1 (3.6)
My guess is trapping at 6200-6300 will make a substantial difference too.
Good to hear from you! Saw you make a few laps too, but never got over to talk. Next time I see you out i'll make a point of it to say hi.Good morning Bob. I agree that he should have no problem hitting low 10's , maybe high 9's.
Glad to see you had the car out. I could only get out once this year.
I hope all is well with you and family... stay safe hope to see you soon. Steve
