nearpar
I have a 1977 440 with flat tappet hydraulic cam is there any oil out there off the shelve with the required ZDDP to run in this engine? If not what would be a safe conventional oil and what is a good additive that I could use that is readily available again off the shelve?
Thank you in advance...
