stock bottom end 360.. bored 0.060 over... adding sidewinder aluminum heads with ARP bolts... what is a good head gasket to run? i have heard so many options from a fel pro to a mopar brand to a cometic..
So, would the FelPro 1008 be the best thing to use on a low-compression 273?Shouldn't need anything special.
Felpro offerings...
Pt 8553 around .046-.048 compressed
1008 .039 compressed 'steel reinforcement ng type'.
519sd .052-.054 compressed.
Whatever head gasket is closest to your cylinder bore. Some of the Fel-pro gaskets are 4.060 bore and up.So, would the FelPro 1008 be the best thing to use on a low-compression 273?
There are some mr gasket, .027 thick or something? but I hear mostly about failures with them...So, would the FelPro 1008 be the best thing to use on a low-compression 273?
That's over 1/2" larger than my 273ci bore! Geez!So I looked and the fel pro 1008 is only offered in 4.180 bore. Thats a big step from the 4.060 I need.
Yeah I have to find sometjing closer to 4.060.That's over 1/2" larger than my 273ci bore! Geez!
so it will work even though the bore size on it is 4.180 and mine is 4.060?The Felpro 1008 will work just fine, that is what I have on my 13:1 compression motor. Used this gasket for many years (20+), no failures....and I have used them with relatively stock applications, nitrous motors, and high compression applications.
Yes, all my motors have been 4.030-4.040. Most of the head gaskets are larger than the actual bore of the cylinder (at least the ones I googled real quick).so it will work even though the bore size on it is 4.180 and mine is 4.060?
awesome.. thank you guysYes, all my motors have been 4.030-4.040. Most of the head gaskets are larger than the actual bore of the cylinder (at least the ones I googled real quick).
For what it worth, my current motor is 0.030 over 360 that is stroked to 408, with the Felpro 1008, 13:1 compression on e85, runs low 10's, no head gasket issues...
Yes it will increase your scr a little but it won't hurt a thing im using the 8553pt in my 360.so it will work even though the bore size on it is 4.180 and mine is 4.060?
