Need help identifying cam
coloradohill
Northern Colorado
I recently purchased a short block and am trying to identify the cam.
I was told that it is a solid lifter cam. Am I correct that it is a Comp Cams 294s grind?
What do the markings signify? 294s-10, um2083-05 , Red paint?
Thank you all for your input.
Looks like a comp by the CC.
Give comp a call and give them the numbers and they will tell you. They can also send you the cam card.
I’ll assume it’s for a SB Mopar, since that’s where you posted.
The Comp 294S for a SB Mopar is part number 20-248-4
