matthon
- Joined
- Aug 29, 2008
- Messages
- 3,704
- Reaction score
- 2,760
67 Barracuda Formula S.
I recently had to replace a tie rod end, bought a Moog: Moog Chassis Parts ES319L Moog Replacement Tie Rod Ends | Summit Racing
Now replacing all 4, read multiple opinions on Moog and the majority state they're junk, but I have no idea.
Proforged doesn't have any negatives I can find, but there are 2 listed for each inner and outer, one twice as much as the other.
The more expensive one is around the same price as the Moog.
Problem is, neither provides any info. Iirc, the stock ones have 9/16 ends, my understanding is that refers to the threads for the sleeves.
I'll be using the QA1 sleeves, and the thread size isn't listed for these but there is only one option: https://www.summitracing.com/parts/qa1-52325
What part number for the Proforged tie rod end?
https://www.summitracing.com/parts/pof-104-10268
https://www.summitracing.com/parts/pof-104-10157
And if Moog is such garbage, should I also get the Proforged lower ball joints?
I have QA1 ucas.
Pic of the recent Moog tie rod.
Also, for some reason, the Moog inner tie rod end is more than the outer, and the passenger side lower ball joint is more than the driver side.
I have QA1 ucas.
