diymirage
HP@idle > hondaHP@redline
those lockouts finally showed up so i installed them
just in time too, the passenger side was starting to come apart, and the drivers side was worn through and letting junk in
all the videos on youpuke were 4 minutes long
turns out it takes just a little bit longer if you actually take the time to clean out the caked on grease, and rust
try turning the dimmer switch
a lot of times, just past "bright" it clicks to "dome light on"
Not today, but last night... checked out a socket.. found a spare 1157 bulb... light works... kind of, it doesn't turn off... is this the incorrect bulb?
