1993 Dakota 2wd frame chart
jos51700
Green Bearing thread connoisseur
Bel-Ray
I recently ditched my Dakota and I need to see if the frame is tweaked. I've looked high and low but can't find a frame measurements diagram. Does any body here know where to find them?
Thank you!
JOSbunchanumbers
I will take a look in my 1993 Dak shop manual and see if there’s something
You might do a Google search for frame dimensions. I tried to paste a link to pinterest of a chart but I couldn't. Sorry
Right out of the 93 shop manual -Don’t know if you’ll be able to read all this. Hope it helps.
Those dimension crack me up. Who goes to the 10th on an inch on the body let alone a 10th of a Millimeter? I hope whoever made that drawing knows they put the Millimeters as reference and not duel dimensioning then in the text the tolerance is in Millimeters. Talk about bass ackwards. I won't even address tolerance stack....
DARTMAN TO THE RESCUE!!!
And ditching a truck is fine. Hitting the cinderblock-sized rocks they piled in the ditch 'because people keep driving into it' is not so good for a pick up. Shattered the front wheel and broke the steering rack in two!
