Minnesota Muscle
Ordered a set of 240's for a stroker build. I couldn't believe how beat up these heads were. The double boxing they were shipped in were spotless, so definitely not the shipper.
Not only were both deck surfaces scratched to hell, but the one head was actually cracked! You could see with a flashlight the crack continued into the triangular water port down inside, but I couldn't get it in a picture. You can clearly see the start of the crack in the photo though.
Also looked like corrosion starting in one of the marred spots.
I didn't bother check over the rest of the heads after seeing what I saw, boxed them up and sent them back as defective. But I have a suspicion these will end up back on the retailers shelf...
So these are the first trick flow heads I've bought, tell me this isn't the status quo...
