340 4 speed
F/A Tech
Vancouver Canada
Finally drove our new 1970 Swinger. WOW so much more power than the 318. With 4 speed and possy traction it will lay rubber through all 4 gears. SOOO much fun.Just got to fix a brake leak ...... so I can stop.
Glad to hear your Swinger is running well but Sure grip is the accepted term on here F/A tech!!
Save the 'Possi" for the chev guys!!
I like well built 340's! Just picked up this from the machine shop Friday. Assembly to begin! 65'
Hey 65, looks like you put plastic all around the engine stand to keep off the over spray, but you got over spray all over the deck and inside the block ?
My motor stands are all different colors just because, but I always tape off the engine.
Nice color, it looks like the color I painted a 400 Chevy small block I did a couple years ago.
Nice paint job on the gasket surfaces.
Hey guys, after painting the block I use acetone to clean all the machined surfaces. I used to tape everything off but find it easier to use the acetone to remove the over spray! 65'
The color is AMC JEEP metallic blue. It matches the 40 Plymouth Coupe I'll be dropping it into! 65'
What gearing do you have? Tires?
Lets see some pictures of that 340.
