jonn6464
1970 Duster
I'm really torn on this. I've found a scoop that I like. It's not a traditional A body scoop, but it is a MOPAR piece. Normally goes on the Ram 1500 trucks. I can't decide if I want to go down this road or not. I'm leaning towards NO, because I really think the Duster has great, clean lines and it doesn't need a scoop. Also, I have a fresh air system that I can use instead of a scoop.
But, I also think the scoop "UP's" the muscle car factor and can look pretty cool. Adding the scoop will require drilling some mounting holes and also cutting a hole above the air cleaner. It's a big decision. Once the first hole is drilled, I'm committed.
What do y'all think about the pics?
Y or N to adding the scoop?
There are some mounting studs at the front of the scoop, that require holes to slide into, so it's not sitting flush. And, it's not exactly centered, but you get the idea.
Also, the color of the car is gonna be a dark charcoal, so the scoop will probably blend into the hood and not be as obvious as if it were on a light colored car.
