If you use my SPC arms, no cutting required, and the bushings are delrin. The other benefit is a much wider range of adjustment, and much easier alignment due to the double adjustable design. The gen 2 upper arm features a taller ball joint which helps mitigate body roll to a degree.
BAC SPC Upper Control Arms - Bergman Auto Craft
SPC 2ND GENERATION MOPAR UPPER CONTROL ARM - Bergman Auto Craft
