Lets see your cars.........
Yes they are 15x8 with I believe 3 7/8 back space. I also run some 15x8s with a 4.5" Backspace but with a 1/8" spacer.
I run a Dana that is narrowed a small amount to fit a 28x10.5 or 275/60 without rubbing.
Could you please share the rear wheel backspace? Are they 15x8's? I want to get that stance and look for my dart.
Hi, been a long time, Yes 15x8's, I had a set of 8" rally wheels on it but they were REALLY heavy, they had 5-1/4" backspace I think, went with the Welds but could only get them in 4.5' BS. so I cut the housing 3/4" each side and lopped the same off the ends of the axles [mosers with about 4" of spline]. Made my own offset spring hangers to move the spring hard against the chassis rail and now had room for 275/50-15 ET streets. Hope this helps
One of these days ill get her home and take a pic of my f4 green dart
