67 K FRAME 360 ENGINE MOUNTS
cawley
383 Bcuda
milton
I have a 67 barracuda & i dont want to go through the trouble of finding & installing a newer K frame. I have a rebuilt 360 i would like to use. Where can i find the correct engine mounts ? Schumacher mounts are no longer in stock along with everyone else.
Is the 67 K a 6 or v8? Only thing wrong, really, with a 67 V8 K is the oddball idler. You can use "stockish" 273/318/ 340 engine brackets you may have to mod them. There was a thread recently bringing this up. Only problem I know of is getting the proper pillow rubbers. The thicker, later, truck ones did not work on my car, engine too high and screwed header clearance.
Here
crackedback, engine brackets - Google Search
And here
1969 dart 360 motor mounts
Here
And here
it was originally a 273 car
No need to spend $$$$ for aftermarket mounts. Just use your original 273 mounting brackets and mounts. You'll need a few washers for a spacer one of the driver's side bolts (you'll figure out which one when you try bolting the bracket to the block, and either just use two bolts on the passenger side, or weld a triangle on the passenger side bracket and drill one hole. Viz:
Ignore the caption at the bottom that says this is a modification for 64-66 273 bracket. This is correct for 67-72.
sounds like a plan thank you
