[WANTED] Desperately need a carb part !!!!
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Holley model 2280 model no. 4016 S
I need the accelerator pump, not the cup that drivers the squirter, but the metal plunger. I have the cup and spring. I was working on it today and my slippery hand couldn’t grasp it fast enuffvand it shot into the tall grass. No luck finding
Aren't carb parts non-ferrous metal?
Maybe try poking around a shop vac, then check the bin.
You can rent a magnetic rake/sweeper at Home Depot or Lowe’s.. roofers use them to pick up roofing nails
Would this kit have the part you need for the Holley 2280 ?
Holley Renew Kit; Carburetor Rebuild Kit
Part # 3-888
30 bucks at AdvanceAutoParts
Sounds like you want to get it back to the customer quickly, no?
Sounds like "30 bucks at AdvanceAutoParts" is the way to go, you're going to spend that to get someone to overnight you a spring
Can rent a metal detector from your local rental center for 1 hour for cheep.
Have used them, they work Awesome. They emit a high pitched whine when you are over the target.
The same high pitch whine the election cheaters are making, now that they are caught . . .
I get calls all the time to help find stuff with my metal detector. They can be a life saver.
Got a pic of the part needed? I have a bin with holley parts and a few old carbs laying around.
