dICKj
Can l temporarily hot wire a mopar ignition by using a jumper from the battery to the coil? I am just unsure about the electronic ignition stuff.
^^THIS^^ and also be aware you "could" have an older 5 pin ECU which requires a 4 pin resistor. Look at the ballast. One end has both terminals jumpered together. This is the incoming "key" voltage. You need to jumper power to that set of terminals. Not that easy, as you need to have both jumpered as well as power to them.If you are going to do it underhood I would go to the resistor so you are not sending it a full 12 volts.
