904 race build
Ceedawg
Va
Looking to see what is the most common parts to use on a 904 race build. Will be my first from doing 727s for many years. Don’t need a ‘pro trans’ and not taking it to a name brand shop, I can buy or machine any part. Let’s hear what you got. Thanks in advance.
https://www.coperacingtrans.com/?product_cat=904-race-rebuild-kits
This is a rebuild kit from Cope Racing
Product Description
904 Rebuild Kit-High Performance Race 72 & up 904-998-999. Includes all Seals, gaskets, O rings, lip seals, sealing rings, 5 thin grooved Alto red eagle clutches for the front drum, and 4 thin smooth or grooved Alto clutches for the rear clutch, 9 kolene steel plates, filter, and a set of teflon rings for stator.Will fit both a stock or billet drum. Fits 1972 & up 904-998-999 torqueflight transmissions.
I got 5 904s in use in bracket cars.....4 with transbrakes and 1 foot brake.....
The 904s with transbrake all have 5 thin clutch disc in the front drum....I use the thin disc and steels from the rear drum....you need a minimum of .060 clearance with the 5 disc....I have had to get the pressure plate cut about .020 on several of them....
I also use the 24 spring kit that replaces the large wound spring in the front drum......a cheaper route is ATi make a single spring that is wound the correct way to keep the front clutches from slipping at high rpm......
I generally use stock steels and stock disc or high energy clutch disc....only used the red alto and kolene steels once...
Front and rear bank I use Kevlar bands.....the rear are the double wraps....
I use the 5.0 kick down lever on the front band along with a heavy duty band strut......
Front servo is stock....Rear servo is a one piece billet design....
re.
The transbrake manufacturer says use Teflon sealing rings on the pump stator because of the line pressure,
I replace the pump bushing...the front drum bushing..and the rear tail shaft bushing and new seals on both ends.
Pump gears are usually stock unless I see something....then I replace with harden gears ......
the 904 stock have a bolt in sprag......just get a replacement roller/spring kit for 10 bucks...
I dont buy kits since the kits dont have what I want.....they give the thick front disc and steels..I usually buy from What ever it takes trans....i order individual parts....and keep enough extra parts to rebuild a 904 on stock if needed...plus I have one complete 904 spare if needed too...
that is my basic trans.....i rebuild them myself....they are simple...
Is the factory slip yoke strong enough for foot brake or stutter box in E/Stock
Using stock yokes on all those trans....7260s.....never have had any problems...launching with Transbrake....couple of cars have run 10.20s
I footbraked my IHRA Dart Sport to a 11.14 ET and 1.47 60' bests for almost 20 years with stock 7260 trans yokes and never broke one. But I also used solid Spicer U-joints, aftermarket driveshaft tubes and billet steel 7260 rear end yokes. Never 2-stepped.
Trans had a 2.74 low gear with a race weight of 3,540+ lbs and a 360.
I do have a CM shaft and solid joints I bought off a guy that’s going to the big stuff. Dana either 4.88, 5.13 or 5.57
Not saying you need to do what I did, but you said you can machine, see pics in my signature to see what I did.
That is some great work you did there, I’ll have to take one apart and compare how you changed each piece. Do you have a list of parts and where you bought them?
Check the pics in my profile. I did my own 904 and lots of custom machining. Email me any questions.
